Where on my D-19D does it go????
M Russell
03-04-2000 05:46:52
I'm looking for someone to tell me where the L bracket goes that supports the oil pressure line to the turbo. The bracket part no# is 4513713 and I believe it mounts on the upper right 1/2 inch bolt that bolts the adapter plate to the rear of the engine block, but to install it there I'll have to pull the engine back so I want to be sure before I start.It could mount on the rear head bolt but that would probably be to easy. I would also like to know if the bracket part no# 236747 that holds the breather tube bolts to the upper starter bolt. I'm restoring this tractor and the engine was torn down when I got it, Thanks for your help. M Russell
