B pushrod
Terry (NC)
03-03-2000 04:29:53
In kindergarten I was tought that the only stupid question was the one not asked but I'm still reluctant.
I'm restoring a "B" (1941) and after removing the valve cover discover that the first pushrod has a nasty bend in it. My problem is that the valve clearance is fine and the engine runs like a well oiled sewing machine. If I didn't pull the cover off I would not have ever know it was bent. My problem is that in over twenty years of turning wrenchs I have never seen an engine that runs so well with such damage. My stupid question is "Is the first pushrod on a model B suppose to have a bend in it"? I can already hear you laughing but I had to ask.
Phil Auten
03-03-2000 05:30:37
 Re: B pushrod in reply to Terry (NC), 03-03-2000 04:29:53
Terry,
No, the first pushrod is not supposed to be bent.
If the bend is so severe that it can't be straightened, I would replace it and reset all the valves. I would also check the valve that pushrod actuates to be sure it's not sticking and also the rocker arm for sticking. Sounds like something went wrong in there somewhere and a P.O. just patched it up. Also, someone may have replaced that pushrod with one that was too long and after the engine warmed up, the bend happened and the owner just tweaked the adjustment until it worked again.
Good luck,
Phil
