WC to WD will it work?
Kemper
03-01-2000 16:55:17
I found a late WC with a newly rebuilt motor, and my question is, does it have the same horsepower as a WD? The motor looks the same and i thought if i could buy it cheap i would swap motors with my WD. Thanks in advance for your info.
Aaron
03-01-2000 17:35:26
 Re: WC to WD will it work? in reply to Kemper, 03-01-2000 16:55:17
If it's newly rebuilt, then I'd guess it's close enough that you'll never notice. The WC does turn 100 RPM slower, so you could swap the governer out, as well as the manifold and carb. Then it'd be the exact same engine.
Aaron
Richard T. Mitchell
02-13-2001 19:53:36
 Re: Re: WC to WD will it work? in reply to Aaron, 03-01-2000 17:35:26
Would a crankshaft for a WD45 workin a WC block to bring the horse power up. And if so what changes would have to be made?
