Crankshaft timing mark.
John, in Pa.
02-27-2000 16:31:31
I have a 42WC,cannot see timing mark on fly wheel.
What kind of mark am I looking for?
Would it wear off in time? If so how do I remark it? Thanks a lot.
Brian G.
02-29-2000 06:30:00
 Re: Crankshaft timing mark. in reply to John, in Pa., 02-27-2000 16:31:31
Tim(ny) is correct. The "F" or "Fire" mark is 30 degrees BTDC which is the correct "advance" for the WC. If you measure 3-1/8" from the "Fire" mark clockwise at the circumference of the flywheel, you will be at TDC.
Brian G.
02-28-2000 06:16:37
According to the manual, there should be either an "F" or "Fire". My WD has an "F".
Tim(ny)
02-29-2000 05:48:04
 Re: Re: Crankshaft timing mark. in reply to Brian G., 02-28-2000 06:16:37
And its not at TDC, if its the same as a WD; its at full advance, which is something like 30 degrees(off the top of my head. So you have to set the timing with the throttle open enough to obtain full advance.
