ALLIS 200-wont go
Dean
02-27-2000 05:19:41
Have a rear end problem,it locked up.When we pull it one wheel turns forward the other backward.Any weak points in them?Any info what to look for will be appreicated.The tractor has not been idle.Thank you Dean
rod bender
02-27-2000 05:29:20
 Re: ALLIS 200-wont go in reply to Dean, 02-27-2000 05:19:41
Dean, it sounds more like somthing in the transmisson went haywire, if the rear end locked up both wheels would slide when pulled. my 4.04% worth.
Dick L
02-27-2000 07:26:29
 Re: Re: ALLIS 200-wont go in reply to rod bender, 02-27-2000 05:29:20
Is this with the clutch down? Is it in or out of gear? If it does this only with clutch up what gear is it in. If you can it pull ok with the clutch down then it is ahead of the clutch. If your trying to pull start it in a low gear this will happen. More information is needed for us to guess at your prblem.
