D-21 HP
Jon
02-23-2000 18:54:24
What is the rated horsepower of a AC D-21? Thanks.
Patrick
02-24-2000 06:12:42
 Re: D-21 HP in reply to Jon, 02-23-2000 18:54:24
D21 PTO HP- 103
D21 Series II PTO HP- 127
Jon
02-24-2000 15:07:49
 Re: Re: D-21 HP in reply to Patrick, 02-24-2000 06:12:42
Thanks. I was thinkin that they were a little more than that. Guess they aren't. Thanks again.
MADDOG
10-30-2002 13:49:42
 Re: Re: Re: D-21 HP in reply to Jon, 02-24-2000 15:07:49
What do you mean " I thought they were a little MORE than that"; every D-21 I've ever run on my CALIBRATED PTO dyno has pulled BETTER than the factory specs; those 3500 Series II Turbo engines will; IF SET UP PROPERLY pull anywhere from 128- 250 PTO horsepower; it's the ONLY DIESEL TRACTOR engine that I've seen in 33+ years of engine rebuilding that will develope this kind of HP. Getting the (factory) D-21 driveline to stay together with this kind of power takes some REAL
engineering; however on the PTO dyno only the straight-thru shafts are turning; wheel differentials,etc., are NOT in the equation.Allis-Chalmers built ALL the D-21s with WAY TOO MUCH Hosepower; they smartened up quickly at the factory,too, after replacing all those (original) D-21 clutches under factory warranty!!
