WD Plow
Gary Kempf
02-22-2000 16:48:14
I have a WD and a three bottom plow,and i just can't get the plow set right, anybody got any sugestions? It wants to go to deep, when i try to raise it a little it will come up too far.
sid
02-22-2000 22:24:40
 Re: WD Plow in reply to Gary Kempf, 02-22-2000 16:48:14
Have you tried adjusting the angle of plow. If not you might try the adjustment on the lift arms connecting the plow.I think if you look you will see it is like a turnbuckle on each side of plow where it hooks on the lift arms. to make the plow go deep you want the plow to tilt to the left with the points going down, just the oppisite if plow is going too deep, tilt plow to the right raising points out of the ground. Also my plow has a crank adjustment to level front to rear that affects the depth to some degree. Your plow might be alittle different but the tiltingof plow asI have tried ti describe Is pretty much common on the different makes of plows that I have used hope this helps Sid
