D-17 Trany
Cory
02-17-2000 14:43:27
Do all d-17s have a high/low range transmission?
GeneD14
02-17-2000 18:24:14
 Re: D-17 Trany in reply to Cory, 02-17-2000 14:43:27
The only exception would be the industrial model. Otherwise all D17's had the high-low power director hand clutch.
Cory H
02-18-2000 05:28:22
 Re: Re: D-17 Trany in reply to GeneD14, 02-17-2000 18:24:14
How does the "hand clutch" provide the high and low range. Thanks gene
Darrell (MN)
02-18-2000 10:24:11
 Re: Re: Re: D-17 Trany in reply to Cory H, 02-18-2000 05:28:22
It's a hydraulicly driven secondary clutch. One half goes straight through, while the other goes through a planitary style drive to either increase or reduce the speed of the output shaft to the rear end. (I think, not completly sure) If this is not right, i'm sure someone will correct it.
Gordon Chance
02-18-2000 17:41:06
 Re: Re: Re: Re: D-17 Trany in reply to Darrell (MN), 02-18-2000 10:24:11
Darrell: The power director clutch is a wet clutch in the D17 but it is mechanically engaged, not hydraulically engaged. Also the low range is driven from a gear on the main clutch shaft that drives a countershaft that drives a hollow clutch shaft that is splined into the low range clutch plates and is not a planetary reduction as you stated. I'm not trying to criticize, just trying to save some confusion and misconceptions. Have a good day.
Gordon
D-17DAVE
02-19-2000 20:19:55
 Re: Re: Re: Re: Re: D-17 Trany in reply to Gordon Chance, 02-18-2000 17:41:06
Gordon,a great description. To add to the question about the [handclutch], it has a neutral possision inbetween hi and low giveing the D-line live power on the PTO. the whole clutch pack is so close on tolorance you can shift on the move like a TA or MULTI-POWER.
