WD-45 won't start
carb?
John W.
02-14-2000 18:46:43
Initially fires up, then quits. Carb floods out (gas pours out through air intake, though choke is off). Would a sticking float cause this, or something else. I've got 6" snow and more on the way, so I'd appreciate some ideas. Tha
DAve Kolby
02-19-2000 09:50:21
 Re: WD-45 won't start - carb? in reply to John W., 02-14-2000 18:46:43
Mine did this. A $30 complete carb rebuild kit for Central Tractor fixed it fine. Easy to use, comes with instructions. In the interm you can dismantle the carb and clean it with compressed air. Peobably the float valve is worn however and sticking. Careful, it can catch fire!
Dave
John W.
02-19-2000 13:58:19
 Re: Re: WD-45 won't start - carb? in reply to DAve Kolby, 02-19-2000 09:50:21
Thanks for all your help. Here's what I did to start it. I opened the main jet another turn and a half. Once it fired up (it took a while) I backed it down to its normal operating position. I'll check the float this spring, just in c
Aaaaron
02-14-2000 19:12:48
I'd guess either the needle and seat are wore, or the float has a hole in it and sank. Could also be something broke loose and is holding the float down. Looks like it's time for a tear down. Hope it's something simple.
Aaron
Joe Green
02-15-2000 19:54:32
 Re: Re: WD-45 won't start - carb? in reply to Aaaaron, 02-14-2000 19:12:48
Sounds like your float might have sunk. I had the same problem on my JD B and my old GMC pickup at the same time. New float in the pickup and soldered the float in the JD, and they both worked fine. Must be a fairly common problem.
