Rod Bearings for a 1941 C
Guyton
02-14-2000 18:38:30
Help! I need a source for .040 rod bearings for a 1941 C. The shaft is past .030 on the rods. I can find .060 bearings but don't want to turn the shaft that much if I can find .040's. Can anyone help. Thanks
Dick L
02-15-2000 06:14:16
 Re: Rod Bearings for a 1941 C in reply to Guyton, 02-14-2000 18:38:30
I can't find a listing for the .040 under. You might want to try a junk yard for another crank, or take it to a shop that builds up and regrinds crank shafts. .060 is a bunch and if you want to work the tractor I personly wouldn't want go that small. If you just want it to run it won't make much difference.
Guyton
02-16-2000 09:00:45
 Re: Re: Rod Bearings for a 1941 C in reply to Dick L, 02-15-2000 06:14:16
Thanks for the information. I have pulled the crank from a parts tractor and to my delight found out this morning that it can get by with .010 on the mains and rods.
