CA only firing on 2 cylinders ( OH
OH )
Doug
02-07-2000 19:39:23
I just got a '52 CA that has been sitting with the engine stuck for 7 years. I pulled the head and worked the pistons til they finally moved, got her to turn over by hand pretty easy. So I replaced the head & gaskets and to my surprise after about a dozen hand cranks she fired up, the problem is its only running on 2 cylinders. My question is do any of you out there think that the reason the other 2 aren't firing is because of the valves ? they were pretty ugly. I'm trying to be optomistic about it. I would really appreciate any help or advice
Ernie D
02-08-2000 15:53:38
 Re: CA only firing on 2 cylinders ( OH - OH ) in reply to Doug , 02-07-2000 19:39:23
Remove the distrubtor cap and verify rotor direction is the way you wired the firing order. If you wire the cap backwards it will run on two cylinders. Handy trick to prevent thievery.
Dick L
02-08-2000 10:43:55
When an engine sets long enough for the pistons to rust enough to keep it from turning over, you have valves that are open and most of the time will rust also. If after you get the head of the valves cleaned up real good and the head of the valve is not oblong and you can see a flat edge all the way around the valve, you can lube the valve stem and tap the valve closed and then work all of them to make sure that they are not sticking open, with good plugs and wires, you might luck out. I have found that most of the time when you have rusted valve stems that the valve seat is pitted. Even when you lap in a pitted seat to where it doesn't miss the valve will burn if you work the tractor hard for a while. The only way you can tell the condition of the valve and seat is to remove the valves. If you don't have the tools to remove the valves I can explain how you can do this with a deep socket and a hammer.
Phil Auten
02-08-2000 05:07:32
Doug,
One old trick I learned years ago was to place the head upside down and pour a little gas in the combustion chambers. Check the intake and exhaust ports for gas. The bad valves will leak gas into the ports.
After sitting that long, you might need to just touch up the valves and seats to eliminate the rust.
Phil
