WD45 transmission shifter housing misc parts
Terry
02-03-2000 08:44:58
I've got a ball, a spring, and an oblong thing. These came out of my shifter housing while trying to line up the forks to go over the syncronizers. How do they go back? Spoke with a local mechanic who told me about the spring and ball, but not about the other part. Does it go under the spring? Don't have a shop manual that gives a breakdown. Any help would be greatly appreciated.
Gene
02-05-2000 16:20:53
 Re: WD45 transmission shifter housing misc parts in reply to Terry, 02-03-2000 08:44:58
Sounds like the interlock plunger that fits in the reverse shift fork up at the shift rail. No it does not go under the spring. Look at the shift rail and the fork and see if there is a hole through the fork up at the shift rail for something to lock the fork to the rail.
Terry
02-05-2000 22:53:00
 Re: Re: WD45 transmission shifter housing misc parts in reply to Gene, 02-05-2000 16:20:53
Thanks Gene, Does that mean I drop the spring in and place the ball on top? Does it push down with a screwdriver or do I need some type of special tool? Thanks for your response.
gene
02-23-2000 13:11:06
 Re: Re: Re: WD45 transmission shifter housing misc parts in reply to Terry, 02-05-2000 22:53:00
No special tools. spring in, ball in, and go for it. Good luck
