Spark Plugs For AC B ?
Mike Huber
09-20-1998 19:00:56
What plug should I use for a AC B ? Thanks Mike Huber
grapeape
09-21-1998 05:42:35
 Re: Spark Plugs For AC B ? in reply to Mike Huber, 09-20-1998 19:00:56
: What plug should I use for a AC B ? Thanks Mike Huber
any brand but champion will work fine. as for the
size, i think it uses a 45 ac delco, but the parts
store will have a listing of it. theyll know proper
gap too, which you should always check before install-
tion. good luck, grapeape
Ted Buisker
09-22-1998 14:52:58
 Re: Re: Spark Plugs For AC B ? in reply to grapeape, 09-21-1998 05:42:35
: : What plug should I use for a AC B ? Thanks Mike Huber
: any brand but champion will work fine. as for the
: size, i think it uses a 45 ac delco, but the parts
: store will have a listing of it. theyll know proper
: gap too, which you should always check before install-
: tion. good luck, grapeape
Just to add a point to this discussion about spark plugs. On tractors equiped with magneto ignition, try to avoid the new resistor plugs. The will shorten the life of your mag. I guess they are designed for electronic ignition systems. G'Day. TED
Chris
09-27-1998 21:51:36
 Re: Re: Re: Spark Plugs For AC B ? in reply to Ted Buisker, 09-22-1998 14:52:58
: : : What plug should I use for a AC B ? Thanks Mike Huber
: : any brand but champion will work fine. as for the
: : size, i think it uses a 45 ac delco, but the parts
: : store will have a listing of it. theyll know proper
: : gap too, which you should always check before install-
: : tion. good luck, grapeape
: Just to add a point to this discussion about spark plugs. On tractors equiped with magneto ignition, try to avoid the new resistor plugs. The will shorten the life of your mag. I guess they are designed for electronic ignition systems. G'Day. TED
Champion J8-c Chris
