Need Distance Metering Device
Dave Bowers
09-19-1998 08:24:05
I need a distance metering device for a pulling sled. Thank you for your consideration.
Dave Bowers [email protected]
1 602 843 2812 fax 843 2861
mm
09-19-1998 14:30:44
 Re: Need Distance Metering Device in reply to Dave Bowers, 09-19-1998 08:24:05
: I need a distance metering device for a pulling sled. Thank you for your consideration.
: Dave Bowers [email protected]
: 1 602 843 2812 fax 843 2861
Hi, Run one of those walking wheels of the rear tires on the sled. Another way is to bolt a tape of a tape measure to the frame of the sled and have a pointer on the box. Then where the box stops the distance is measured on the sled not the track. Some people don't like this but if it is the same for everybody it is ok.
Keith
09-19-1998 19:59:39
 Re: Re: Need Distance Metering Device in reply to mm, 09-19-1998 14:30:44
i especially like the tape on the side of the sled. it's fair, cheap, and reliable. sometimes the distance wheels slip, or get stuck. if you really want to spend the big $$ you could buy a laser.
