Allis Chalmer H-3 Bulldozer
Richard M. Knud
09-16-1998 22:02:25
Will not go backward, when I use the s-clucth to go backward it kills, brake are off so that not the problem, will go forward but I think I smell something, really need help to get it going
Thanks Richard
Koeckeritz Exc.
11-20-1998 12:25:53
 Re: Allis Chalmer H-3 Bulldozer in reply to Richard M. Knudsen, 09-16-1998 22:02:25
: Will not go backward, when I use the s-clucth to go backward it kills, brake are off so that not the problem, will go forward but I think I smell something, really need help to get it going
: Thanks Richard
; ;Find a manual for tractor FAST sounds like clutch pack for for/rev is sliping. Could be worn out or could be broken spring in S/valve body That was problem on my HD4 replaced weak spring on reverse side of spool in valve body and no problen.Clutch is in oil and hyd. applied in both positions. check hyd pressure at lines to clutch slave ..seen add on this or dstratton page I have seen people who have copys. H4 info same.
