Serial Number
tom
01-24-2000 11:08:13
Can some one direct me to a site I can track down a S/N? I found this tractor w/loader for a good price and was trying to get some history. The number is U 3019-38 if I have the correct number from the block. Thanks in advance for any help
tom
Mike Schwartz
01-24-2000 18:44:36
 Re: Re: Serial Number in reply to Grandad, 01-24-2000 11:43:30
The number that you have given in the casting number for the block. I think that is the casting number used on the WC or WD blocks. Engine serial number would be on the opposite of the engine, stamped into a machined flat spot below the carb to air cleaner hose. Tractor serial number will be on the rear center of the rearend if it is a WC or off to the left if it is a WD or WD45.
