WILL A D-15 SERIES II OUT PULL WD 45
BRIAN
09-15-1998 23:56:44
ALSO WHATS THE REAL HP RATING ON BOTH OF THEM.
Denny
09-18-1998 19:59:38
 Re: WILL A D-15 SERIES II OUT PULL WD 45 in reply to BRIAN, 09-15-1998 23:56:44
Brian, I love this kind of question because it brings out
deap seated feelings. Since I don't have hens to practice on like Nathan does (I must assume he tried to pull a hen off a nest with a WD-45 or he clearly wouldn't have made such
a statement), so I just consult Nebraska to see which tractor pulled the most weight. That should be fair to make a choice
so you don't need any of Nathan's hens. The maximum drawbar
pull of the WD-45 gasoline was 5441 #. The WD-45 diesel pulled
a maximum of 5908 #. The D-15 maximum was 6157 #. So at least in Nebraska. the D-15 seems to be slightly stronger. Also the testweight of the D-15 was slightly less than either WD-45.
Now if the average hen weighed 3# and could fight like the devil,
it might take 10# to get her off the nest. So a D-15 could pull
off 600 average sized hens. That must be some hen that Nathan has!
Regards,
orangeman
09-16-1998 09:23:19
No other tractor in its weight class will out pull a wd-45 unless it is set up with 38 inch wheels or other such advantages. The 226 engine coupled with the tractor's balance, the traction booster system, and that quick governor all add up to a lot of power from a light tractor.
: ALSO WHATS THE REAL HP RATING ON BOTH OF THEM.
Nathan
09-16-1998 17:54:30
 Re: Re: WILL A D-15 SERIES II OUT PULL WD 45 in reply to orangeman, 09-16-1998 09:23:19
: No other tractor in its weight class will out pull a wd-45 unless it is set up with 38 inch wheels or other such advantages. The 226 engine coupled with the tractor's balance, the traction booster system, and that quick governor all add up to a lot of power from a light tractor.
: : ALSO WHATS THE REAL HP RATING ON BOTH OF THEM.
The wd 45 Alice can't pull a hen out of a nest.
Dave Bowers
09-16-1998 17:42:22
Both are 40Hp, but I would bet on the WD45.
Dave Bowers [email protected]
1 602 843 2812 fax 843 2861
grapeape
09-16-1998 06:16:54
wd45 gas with the g226 engine was rated at 37.85 drawbar hp
d-15 gas with the g160 engine was rated at 38.33 drawbar hp
sounds like a tie hp wise but the 226 engine will produce more torque in my opinion, thus it wins!
grapeape
09-16-1998 05:56:46
nope
