Tractor Tilt Sensor
Richard
01-23-2000 07:21:48
First, thanks to all who replied on the CA Brake Bands. I'm going to attempt it in a couple of weeks.
I have heard over and over the dangers of a tractor flipping over caused by the implement suddenly stopping causing the front end to come over.
This seems like a very easy fix. I was picturing a mercury tilt switch with a murphy tattletale to disconnect the ignition after so many degrees (45 or whatever you set it at). The reason for the murphy switch is to keep the ignition from coming back on on the way down, allowing the governor to go wide open.
If the tractor came up far enough, it would trip the murphy tattletale and the tractor would die. You would then have to push the reset button in order to restart the tractor.
Does anyone have any comments on such a device, or do they already exist? This could be a $10 to $20 addon and possibly save a life.
Richard
John.CO
01-28-2000 23:37:17
 Re: Tractor Tilt Sensor in reply to Richard, 01-23-2000 07:21:48
We've experimented with a similar switch as an alternative to wheelie bars on pulling tractors. Tested prototype on several tractors, mag and dist. and worked OK. Didn't use the Murphy switch, as load was so great that engine couldn't recover.
John
Rob in MO
01-23-2000 09:19:54
It would be hard for a liquid switch to differentiate between the angles caused by the front wheels leaving the ground, as in a rollover, and the angle caused by climbing a steep hill even though the wheels are still on the ground. Losing ignition on a steep grade could be just as deadly if the brakes and/or transmission couldn't hold the tractor to reset and restart. If, in your individual case, you don't foresee any cause other than a flip over tripping the switch (including trailering) it sounds like a good idea for you.
Skip Gosnell
05-28-2002 10:15:12
 Re: Re: Tractor Tilt Sensor in reply to Rob in MO, 01-23-2000 09:19:54
Rob and Richard,
Ever consider an electronic tilt indicator? Rough and weatherproof, it can be set at a variety of angles, gives off an audible alert (compensated not to go off on bumpy roads)so you can keep your eyes on the terrain ahead. Anyway check out www.riekerinc.com.
