A-C Model B- need info
DavidZ
01-21-2000 21:53:44
I am going to go look at a model B allis tomorrow at an auction. Can someone give me some pointers on what problem areas to look for. Are these tough to get parts for? Anything I really need to check out? Any special options or trannys? Thanks
Darrell
01-22-2000 07:02:35
 Re: A-C Model B- need info in reply to DavidZ, 01-21-2000 21:53:44
If you have the time look at the rear wheel where they go on the axel and see if there is any play in them, but like Grandad said there isn't anything that I know of that you can't buy for them. You also might look at the front end and the touque tube for any cracks in the castings, if there would be any that might be a little bit more costly to repair. Good luck, they are a lot of fun to work on.
Grandad
01-22-2000 01:08:47
You can get almost anything for the B, new or used, that you would need. The exception might be an original gas cap. The best options were belt pully, PTO and hydraulics. On the early Bs it was nice to have lights and starter. If possible drive it in all gears and check for noise from the final drives and transmission. Oil pressure should be 10 to 12 psi or around the R on the word normal on the gauge. Good Luck
