CA slow to go?
t delewese
01-21-2000 07:30:42
My ca when in gear- forward or reverse moves very slowly and then eventually moves faster. No noise. does any one have an idea what my problem might be? ?
Grandad
01-21-2000 07:41:51
 Re: CA slow to go? in reply to t delewese, 01-21-2000 07:30:42
Sounds like either the main clutch or the hand clutch is slipping. It may need adjustment. The reason it pulls better after a bit is that it has heated up and expanded so it makes better contact.
Better check it out. It might get expensive if you let it go.
t delewese
01-21-2000 11:05:20
 Re: Re: CA slow to go? in reply to Grandad, 01-21-2000 07:41:51
to grandad, thanks. the final drive clutch is in however the lever and adjustment have been removed when a new final drive was installed. would that clutch be activated if those parts were not intact? Is there a way to check the main clutch without breaking the tractor? thanks tdelewe
