Sick little B
Michael Yehl
01-19-2000 05:43:12
I've got a B (1939) which only will start when it is cold. I've rebuilt the mag... what else could it be?
Phil Auten
01-19-2000 19:36:57
 Re: Sick little B in reply to Michael Yehl, 01-19-2000 05:43:12
Michael,
Does it have spark when hot? If not, check the hot coil for continuity. It might be opening up hot. It also could be breaking down hot so check it on a high resistance range for any kind of a reading between windings. It should be an open circuit with absolutely unfinite resistance. Any reading at all is bad. This can be done from the center tower on the cap to ground with the points open.
Also, just go ahead and replace the condenser. It is one of the most likely parts to fail and it's cheap too (I think I'd start there).
Phil
Rick in NC
01-19-2000 09:58:14
Mike,
Is the mixture setting on your carb. correct? Perhaps the carb. needs the denser cold air to achieve the correct mixture of air/gas to start.Try turning out the mixture screw to give it more air.
Mine was adjusted way too far the other way and wouldn't start.
Good Luck!
