Allis C hydrolic cylendar and pump
Ossie
01-18-2000 18:13:37
Having trouble getting lift to work on AC "C" took cylendar off and found no O rings or anything in there ... only a rod with a nut on the end and a four sided piece on the shaft..what holds the hydrolic fluid and could it be possible that the cylendar is ok and the pump is bad ,have not checked the pump for pressure but it works very slowly and is quite weak, can push the lift back down when the pump is engaged and sould be lifting ..any help appricated .... also the left rear final drive barring is bad and there is no nut or bolt to retain the axle on the tractor it appears that this is missing anyone have a diagram of this or can tell me how this should look, think I can get the barring from the local parts house ..thanks
