Wd45 cylendar head torque specs.
Ken
01-18-2000 08:21:02
I need to know the proper procedure to torque
down the head on a AC WD45. Any help will be grately appreciated.
Phil Auten
01-18-2000 08:41:29
 Re: wd45 cylendar head torque specs. in reply to Ken, 01-18-2000 08:21:02
Ken,
Generally accepted cylinder head tourquing practice is to start as close to the center of the head as possible and work out toward the ends in a spiral pattern. Go through this at least three times, first at about 50-60%, next at about 80% and finally at 100% of torque value. Let it sit overnight and retorque. Run it for about two hours and retorque after it cools down. I usually check it a couple more times after working the tractor a week or so. This seems to have worked for me.
Phil
Brian G.
01-19-2000 07:03:53
 Re: Re: wd45 cylendar head torque specs. in reply to Phil Auten, 01-18-2000 08:41:29
Phil's procedure sounds good. The manual says to "retighten after engine has reached operating temperature". Incidentally, the torque values are: 1/2" studs 70 lbs..... 3/8" studs 25 lbs.
