Opinions requested on the WD45 please
Fargo
09-07-1998 16:05:19
Am considering purchasing a WD45 to use a general purpose tractor for non farm 200 acre property. Currently using an 8N but sometimes I need more power and 3pt lift capacity.
What do people think of this machine? Is it good for GP work? What are the known mechanical pitfalls of this tractor?
Is leaking oil everywhere but I thought it might be an easy tractor to do my first tear-down. I know the guy who is selling it. He says it is a good runner that does not burn oil and hydraulics work well. He will probably sell it to me relatively cheap. It has a 3pt on it.
Thanks
orangeman
09-10-1998 11:54:25
 Re: Opinions requested on the WD45 please in reply to Fargo, 09-07-1998 16:05:19
The AC WD-45. Quite possibly the finest tractor ever made. Tremendous power and reasonable traction with small wheels. These tractors outworkedr their contemporaries. Tractors such as the JD A or 60 and 70 and the Farmall M's and super M's A WD 45 can outpull an 8N on two cylinders. AC took a basic design that began with the WC and perfected it in the WD45 You won't be sorry, especially if it already has the 3pt conversion. Am considering purchasing a WD45 to use a general purpose tractor for non farm 200 acre property. Currently using an 8N but sometimes I need more power and 3pt lift capacity.
: What do people think of this machine? Is it good for GP work? What are the known mechanical pitfalls of this tractor?
: Is leaking oil everywhere but I thought it might be an easy tractor to do my first tear-down. I know the guy who is selling it. He says it is a good runner that does not burn oil and hydraulics work well. He will probably sell it to me relatively cheap. It has a 3pt on it.
: Thanks
Ole
09-14-1998 19:10:49
 Re: Re: Opinions requested on the WD45 please in reply to orangeman, 09-10-1998 11:54:25
: The AC WD-45. Quite possibly the finest tractor ever made. Tremendous power and reasonable traction with small wheels. These tractors outworkedr their contemporaries. Tractors such as the JD A or 60 and 70 and the Farmall M's and super M's A WD 45 can outpull an 8N on two cylinders. AC took a basic design that began with the WC and perfected it in the WD45 You won't be sorry, especially if it already has the 3pt conversion. Am considering purchasing a WD45 to use a general purpose tractor for non farm 200 acre property. Currently using an 8N but sometimes I need more power and 3pt lift capacity.
: : What do people think of this machine? Is it good for GP work? What are the known mechanical pitfalls of this tractor?
: : Is leaking oil everywhere but I thought it might be an easy tractor to do my first tear-down. I know the guy who is selling it. He says it is a good runner that does not burn oil and hydraulics work well. He will probably sell it to me relatively cheap. It has a 3pt on it.
: : Thanks
Please don't lie to the gentleman my neighbor had one and couldn't pull a hen out of a nest.
Killer Allis
09-15-1998 17:45:49
 Re: Re: Re: Opinions requested on the WD45 please in reply to Ole, 09-14-1998 19:10:49
: Please don't lie to the gentleman my neighbor had one and couldn't pull a hen out of a nest.
I suppose their are always going to be some who disagree, however, my first introduction to the WD45 came in 1958 when my Uncle bought one to replace his Massey-Harris #22. The WD45 has been on the farm ever since and today it runs almost like new. They are simple to work on. Relatively inexpensive to repair/restore and should handle most of the jobs you have in mind. I like them to much I just bought another one -- they suit me fine. Of course, I never used it to pull a hen out of a nest, but then again, who would!
toggle
10-27-1998 20:02:07
 Re: Re: Re: Re: Opinions requested on the WD45 please in reply to Killer Allis, 09-15-1998 17:45:49
: : Please don't lie to the gentleman my neighbor had one and couldn't pull a hen out of a nest.
: I suppose their are always going to be some who disagree, however, my first introduction to the WD45 came in 1958 when my Uncle bought one to replace his Massey-Harris #22. The WD45 has been on the farm ever since and today it runs almost like new. They are simple to work on. Relatively inexpensive to repair/restore and should handle most of the jobs you have in mind. I like them to much I just bought another one -- they suit me fine. Of course, I never used it to pull a hen out of a nest, but then again, who would!
My great unlce has one that has been on the farm ever since my great great grandpa farm and it is a really good running tractor. Plus it has not had any major maintance but still runs like a top. It has done just about anything you can think. From sawing wood to grading the lane,plowing the garden, hauling hay and etc. So i would say that the WD45 is a good pick.
Where did the chicken come in must of been a realllll lllll lllll y stupid one .
Dave Kolby
09-07-1998 17:29:42
: Am considering purchasing a WD45 to use a general purpose tractor for non farm 200 acre property. Currently using an 8N but sometimes I need more power and 3pt lift capacity.
: Thanks
This is an excellent, hard working, reliable tractor! Oil leaks can be from several sources. Two common ones are the valve cover and the front main bearing seal, both easy to fix. Third can be a rear seal which reguires engine removal. I have used these tractors since they first became available as the straight WD in 1948 and there are no real problem areas other than the usual such as clutch wear, brake wear, etc. They will pull about anything you can hitch them too within reason and have always been very reliable for me. A lot depends on the care given the machine thorughout its life.
Dave
Fargo
09-14-1998 05:31:32
 Re: Re: Opinions requested on the WD45 please in reply to Dave Kolby, 09-07-1998 17:29:42
: : Am considering purchasing a WD45 to use a general purpose tractor for non farm 200 acre property. Currently using an 8N but sometimes I need more power and 3pt lift capacity.
: : Thanks
: This is an excellent, hard working, reliable tractor! Oil leaks can be from several sources. Two common ones are the valve cover and the front main bearing seal, both easy to fix. Third can be a rear seal which reguires engine removal. I have used these tractors since they first became available as the straight WD in 1948 and there are no real problem areas other than the usual such as clutch wear, brake wear, etc. They will pull about anything you can hitch them too within reason and have always been very reliable for me. A lot depends on the care given the machine thorughout its life.
: Dave
Thanks guys
