AC-B Clutch Stuck After 4.75 Rain.....Why??
Bo
01-15-2000 20:43:55
Clutch working fine before rain about 10 days ago.
Now pushing pedal will not disengage clutch....any help appreciated.
Prosperity to All
Bo
Dave Neubert
01-16-2000 04:44:48
 Re: AC-B Clutch Stuck After 4.75 Rain.....Why?? in reply to Bo, 01-15-2000 20:43:55
Water has got on the clutch and rusted it bonding the disc to the flywheel and pressure plate.Push start tractor in a high gear push in clutch and keep in wile hitting brakes.This should break clutch loose.
Brian G.
01-16-2000 06:48:06
 Re: Re: AC-B Clutch Stuck After 4.75 Rain.....Why?? in reply to Dave Neubert, 01-16-2000 04:44:48
When I was a kid back in the 40s & 50s, my father used to use the "Clutch Pedal Lock" on his "B" whenever the tractor was not going to be used for a period of time. Prior to that, I remember the clutch disc "rusting" to the Flywheel/Pressure Plate a couple of times. The "cure" was exactly as Bo describes. In later years, I wondered if "locking out" the clutch had a detrimental effect on the clutch springs although we never had any problems with the clutch at all.
