Allis-B Info
Mitch Basich
01-10-2000 05:11:48
Thanks to all that replied on my previous ad. The B I have found starts with a crank,has no pto,and has a wide front. Is this an industrial model? It is in very good shape,what would it be worth? Thanks ,Mitch
Darrell
01-10-2000 07:26:20
 Re: Allis-B Info in reply to Mitch Basich, 01-10-2000 05:11:48
Mitch, All of the Allis B's were wide front, as for the crank start, and PTO, belt pully and hydraulics, on the early models these were all options, then as the model progressed, they all became standard. Brian has a good point, they have both pictured here, you should be able to see the differences in the B and the IB.
Phil Auten
01-10-2000 07:21:16
Mitch,
All B's should have a wide front, either the standard fixed "wishbone" axle or the adjustable axle.
A B in good shape with all it's parts like you describe will probably be worth less than $1,000.
Not having a PTO is a drawback IMHO, that will reduce the value substantially.
Phil
Brian G.
01-10-2000 05:35:50
Go to the left and click on Photo Gallery. There are pictures of both a standard "B" and an "IB" (Industrial) version.
