Re: AC- CA single (1) front wheel???
Brian
01-06-2000 04:58:36
The CA usually comes with a wide front on it so a single front is a little out of the ordinary. For 1950 the CA replaced the model C with a little more power and more options. The CA is a pint sized WD in that it has all of the same features except power steering. The traction booster system makes this a great machine to plow with. 3 point kits are available. If the tires are good then $500 sounds ok, but maybe I would try to haggle a bit. Hope this helps, Brian.
