'41 C need direction on loose shift lever
little41c
07-08-2009 07:33:45
Good Morning! I need to do some work on the shifting mechanism of my �41C. My grandson was sitting on the seat, driving with his �mouth motor�, moving the steering wheel and �working� the gear shift. Somehow he shifted it into a gear and the gear shift was apparently pulled up. This �locked� the tractor into gear without the gear shift being in the correct spot to effect any gear changes. I took the side panel off and got everything properly aligned and working again. A few days later I �bounced� across a ditch and the trans locked into a gear, 2nd I think. By rocking the tractor back and forth I was able to get it to unlock and again shift correctly. There is a lot of play in the shift lever, both in the normal shifting range and the shift lever itself lifts beyond what I think is acceptable. I�m thinking shifting forks and shift lever pilot washer. What needs to be done and how do I go about it?
