D-14 power director
claucherty
08-29-1998 18:35:48
I keep slipping out of low range under little or no load with this tractor. High range is fine, are there shim adjustments to the low range or am I looking at something more substantial? thanks for any info.
Dan D.
08-30-1998 09:00:14
 Re: D-14 power director in reply to claucherty, 08-29-1998 18:35:48
: I keep slipping out of low range under little or no load with this tractor. High range is fine, are there shim adjustments to the low range or am I looking at something more substantial? thanks for any info.
There are shim adjustments. You take them out one place and reinstall in another while measuring distances between plates in the clutch. It's done through the cover behind the lever. You need a manual to do it correctly.
