Allis B C, Plow info
T-Tim
12-26-1999 06:37:48
Neighbor just bought an Allis. They're not sure if it's a C or B. Wants to pull a two bottom plow (I'm not sure what size). What is the B/C rated for??, Thanks...Hope ya all had a good X-mas.
robert mull
12-27-1999 05:01:16
 Re: Allis B C, Plow info in reply to T-Tim, 12-26-1999 06:37:48
Down here in this north Ga. red clay we used a Athens two disk semi-mounted turning plow with our "C". I have now a two disk mounted plow I use with my "CA". Bottom plows did not get popular in this area until the early 60's.
Grandad
12-26-1999 17:25:47
The B and C were both rated as a one plow tractor however in very good, loose soil, conditions could pull 2 14's if you could get traction. Allis built a one bottom pickup plow for the B/C tractors. I just got one of the B/C plows and am getting it ready to try in the spring.
Phil Auten
12-26-1999 15:24:43
T-Tim,
Have your neighbor look just in front of the shift lever. There will be a cast in "TRACTOR NO" with a flat spot next to it. The S/N will be stamped on the flat spot and will begin with the model letter as in Bnnnnn or Cnnnnn. The nnnnn's represent the serial number. Might have to scrape paint to read it.
I seem to remember that the B was a one plow tractor and the C a two plow tractor. Since they have the same engine, there must be a difference in the gearing.
Phil
Darrell
01-05-2000 00:31:40
 Re: Re: Allis B C, Plow info in reply to Phil Auten, 12-26-1999 15:24:43
Phil, one small correction, both the B and C were one bottom plow tractors, they have the same engine and transmission, but the difference is a B is a 1 row tractor, and a C is a 2 row tractor, when it comes to row croping.
dan from ohio
12-26-1999 08:17:20
my model B is equiped with a single bottom
plow.I never tried anything more. good luck
