Cylinder head torque Model (B)
Rob R
12-25-1999 16:10:12
I've found two different torque values for the cylinder head (45 ft-lbs or 65 ft-lbs). What is the correct torque?
Mississippi
01-06-2000 06:59:39
 Re: cylinder head torque Model (B) in reply to Rob R, 12-25-1999 16:10:12
Let me throw another one in. My manual says to torque B engines to 60 lbs, run engine up to operating temature and then retighten. If worst comes to worst, get the bolt specs and go with that ie the grade bolt and size all have a max torque for the particular size and grade as set by the SAE. Check in repair manuals or parts stores. You should be able to find the max torque for the head bolts. If the max is higher than the 65 lbs you have I would not exceed that though. You could pull threads from your block.
Brian G.
12-25-1999 16:44:57
According to the I & T Service Manual, the heads on the B, C, CA & RC are to be tightened progressively from the center outward. "Retighten after engine has reached operating temperature." Tighten to 60 foot pounds of torque. Brian G.
