WD Firing Order Cylinder #'s
Larry
12-24-1999 17:13:10
According to the Tune-Up Specifications page on this website, the firing order for a WD is 1-2-4-3. Are the cylinders numbered 1-2-3-4 from front to rear, or are they numbered differently? Also, my WD was converted to a distributor. The Delco-Remy distributor cap has the number "1" between 2 of the posts on the cap. Can anyone tell me which post on the cap is considered #1. I'm kind of up a creek. I ran out of gas in the pasture. By the time I got back to the tractor with some gas, my cattle had chewed and pulled all the spark plug wires off of the tractor (I wonder if they have been watching the neighbor's goats). Anyway, now I have no reference point to compare to. Any help would be greatly appreciated.
Larry
Jeff Halla
01-16-2001 17:05:55
 Re: WD Firing Order Cylinder #'s in reply to Larry, 12-24-1999 17:13:10
I need to know the firing order for my distributor cap on a 93 ford ranger with a 3.0L v6 and the order of the cylinders. looking from the front of the vehicle
Brian
12-24-1999 17:34:55
The cylinder in front is #1 followed by #2 and so on. I think the distributor turns clockwise, so the 1 on the cap I think should be between the 1and 4 posts on the cap. If it won't run, just move them all in succesion around the cap untill it does. It may backfire loudly, but it won't hurt anything. Hope this helps, Brian.
firing order
12-24-1999 17:46:18
 Re: Re: WD Firing Order Cylinder #'s in reply to Brian, 12-24-1999 17:34:55
1-2-4-3
gene
01-05-2000 13:10:19
 Re: Re: Re: Re: WD Firing Order Cylinder #'s in reply to NORM, 12-25-1999 18:11:24
depending on the engine the order may be 1 3 4 2.
