Will a D-17 pull a 6ft chisel plow
Sam
08-28-1998 11:47:09
CAN A d-17 PULL A SIX FEET CHISEL PLOW .what do you think.If so has anybody send one do it.
keith
10-24-1999 15:01:02
 Re: Will a D-17 pull a 6ft chisel plow in reply to Sam, 08-28-1998 11:47:09
: CAN A d-17 PULL A SIX FEET CHISEL PLOW .what do you think.If so has anybody send one do it.
I have ford 901 that I use to pull a 5 shank chisel plow at 8 inch depth it takes 8 to 10 hp per shank
Ron Hart
08-28-1998 18:01:34
A D17 will play with a 6 ft. chisel plow.
wmg
09-01-1998 09:55:07
 Re: Re: Will a D-17 pull a 6ft chisel plow in reply to Ron Hart, 08-28-1998 18:01:34
: A D17 will play with a 6 ft. chisel plow.
Yeah, if you're pulling it through sand. If you go deeper than 4 inches, you'll need more guts than a D-17 will give you.
Don
10-23-1998 19:53:42
 Re: Re: Re: Will a D-17 pull a 6ft chisel plow in reply to wmg, 09-01-1998 09:55:07
: : A D17 will play with a 6 ft. chisel plow.
: Yeah, if you're pulling it through sand. If you go deeper than 4 inches, you'll need more guts than a D-17 will give you.
It sure will: Just don't put it in the good earth!!
