WF or WC
clive morris
12-22-1999 15:04:33
Could somebody tell me the main differences between a WC and Wf model.
I think I have a 1937 WF but I would like to be sure. Thanks
Clive Morris
Phil Auten
12-23-1999 10:01:28
 Re: WF or WC in reply to clive morris, 12-22-1999 15:04:33
Clive,
The WF is the "standard" version of the WC. It has a non adjustable wide front, but otherwise is similar to the WC. Rob is correct, all AC tractors serial numbers are prefixed with the model designation. Sorts makes it easy to identify one.
The S/N should be stamped in a raised area just above center of the differential housing (on the "pumpkin"). Just above the S/N will be stamped "TRACTOR NO" and the lower line is the S/N.
Hope this is helpful,
Phil
Rob in MO
12-22-1999 15:32:53
What is the serial number? A WC sn should begin with a WC, and a WF would start with a WF. Both models' serial number should be stamped on the rear differential housing.
