D-21 Series II
Dave Neubert
12-18-1999 19:04:11
Does anyone know where the serial number is located on this tractor. And what would it take to get this tractor down to 7,000 lbs.
D-21 NUT
12-22-1999 21:48:17
 Re: D-21 Series II in reply to Dave Neubert, 12-18-1999 19:04:11
The serial number is stamped on the torque housing (bellhousing)vertically in 1/2" numbers on the starter side of the tractor near where the engine block joins it. It should read D 21 XXXX. The engine also has a metal plate attached on the block above the starter and below the head. All D-21's had 4 digit serial numbers between 1001 and 4609.
The years and serial numbers are:
1963 -- 1001 - 1416
1964 -- 1417 - 2078
1965 -- 2079 - 2129
Series II - Turbocharged series
1965 -- 2201 - 2407
1966 -- 2408 - 2862
1967 -- 2863 - 3776
1968 -- 3777 - 4497
1969 -- 4498 - 4609 There were 1,128 D-21's built and
2,329 D-21 Series II built. Hope this helps.
Diet
12-18-1999 22:51:49
The lightest I ever heard of a D-21 getting was Dennis Johnson's 5500. Naturally he won a Bush puller's title with it. 7000 should be much work by comparison. As I remember the tail he added two 90's to get up to 5500.
