WD45 Shifter problems
Terry
12-17-1999 18:51:17
Can anyone tell me if there is a kit containing the seal and lock ring for the shifter on a WD45? My shifter lifts up causing the transmission to lock in gear. Trying to plant dear one's winter flowers, so she said I could actually buy a tractor part. Thanks, Terry
freddy
12-21-1999 11:44:15
 Re: WD45 Shifter problems in reply to Terry, 12-17-1999 18:51:17
Had same problem, replaced lockring, welded up shifter ball and pins, not much help. Fixed it like this: made an L-shaped bracket that attaches to steering column, shifter fits through a big hole in bracket. The bracket has about a 2" diameter coil compression spring under it that presses down against the lockring. I think we got the spring from a VW bug shifter, not sure, any spring of the right diameter will probably do. The spring holds the shifter down in the cover, keeps it from popping out of the forks. Hasn't locked up since. Good luck, Freddy
Rick Wisehart
12-17-1999 21:08:10
Get dear one a boy friend, that will give you more time to spend on your tractor. next find a agco dealer to get your parts .even better have dear one and her boy friend pick them up for you.
Rick Wisewhat
12-18-1999 11:21:48
 Re: Re: WD45 Shifter problems in reply to Rick Wisehart, 12-17-1999 21:08:10
CAN BE
Brian G.
12-18-1999 05:28:46
Rick Wise what??
