DO THEY MAKE A GRADER BLADE FOR A AC SNAP COPLER
MARK
08-26-1998 09:18:46
I HAVE A D-17 WITH A SNAP COUPLER AND I AM LOOKING FOR A GRADER BLADE FOR IT .ALL OF MY OTHER IMPLEMENTS ARE SNAP COUPLER OR WHEELED.
Ted Buisker
08-27-1998 04:47:21
 Re: DO THEY MAKE A GRADER BLADE FOR A AC SNAP COPLER in reply to MARK, 08-26-1998 09:18:46
: I HAVE A D-17 WITH A SNAP COUPLER AND I AM LOOKING FOR A GRADER BLADE FOR IT .ALL OF MY OTHER IMPLEMENTS ARE SNAP COUPLER OR WHEELED.
Prbably the best rear mounted scaper blade ever built was made by Allis Chalmers. Because of that you can expect to pay dearly for one, but this is one case where you get what you pay for. Most of the aftermarket blade are too light to do much and do not have any adjustments other than angle. An AC blade can be adjusted several different ways, including tilt, pitch,and angle. Expect to pay $400 to $750 for a real good AC blade.
Mike Huber
08-27-1998 05:01:08
 Re: Re: DO THEY MAKE A GRADER BLADE FOR A AC SNAP COPLER in reply to Ted Buisker, 08-27-1998 04:47:21
: : I HAVE A D-17 WITH A SNAP COUPLER AND I AM LOOKING FOR A GRADER BLADE FOR IT .ALL OF MY OTHER IMPLEMENTS ARE SNAP COUPLER OR WHEELED.
: Prbably the best rear mounted scaper blade ever built was made by Allis Chalmers. Because of that you can expect to pay dearly for one, but this is one case where you get what you pay for. Most of the aftermarket blade are too light to do much and do not have any adjustments other than angle. An AC blade can be adjusted several different ways, including tilt, pitch,and angle. Expect to pay $400 to $750 for a real good AC blade.
Ted is right about the price of a AC blade in good shape My local Agco dealer offered me $500.00 on the spot for mine it took me by surprise! These blades are heavy and can be adjusted to any position I still have the blade
Mike Huber
orangeman
08-26-1998 14:17:12
I have seen aftermarket snap coupler blades at larger machinery auctions. They look to be category l and usually run about $250.00 new.
Mike Huber
08-26-1998 11:17:42
Yes they did make a grader blade for snap coulpler they are hard to come by here in Michigan anyways, I have 2 for my D-17 one is a oringinal the other is home made buts works OK I'm selling the home made one if you can't find a oringinal Mike Huber
