V8 powered HDG6
Dennis
12-11-1999 21:23:40
I recently traded for an HDG6 Allis dozer. The engine had went bad and the previous owner had repowered it with a Chevy 350 and truck 4 speed in front of the dozer trans.. It works pretty good but I would like to replace the 4 speed with an automatic. Has anyone had any experience or knowledge on a conversion like this.
uh
12-12-1999 14:31:38
 Re: V8 powered HDG6 in reply to Dennis, 12-11-1999 21:23:40
Why do you want a automatic? The only vague positive is the torque converter. With all the gear multiplication you have the torque converter in unnecessary.
Dennis
12-12-1999 17:27:27
 Re: Re: V8 powered HDG6 in reply to uh, 12-12-1999 14:31:38
With a decellerator pedal and an auto-trans it would be possible to shift from forward to reverse and vise-versa without clutching and shifting and if you were having to back along way you would have more speeds to choose from at lower RPM. You would have a setup similar to the way the newer dozers are setup. If you have ever watched a newer dozer work you would have to agree this is a big improvement.
uh
12-12-1999 20:50:01
 Re: Re: Re: V8 powered HDG6 in reply to Dennis, 12-12-1999 17:27:27
Since you seem stuck on being a shiftless operator: You need a very short automatic yet one that is stout. A THM-350 would be the smallest I would recommend. The next question is how long is the driveshaft between the 4 speed and the input shaft of the dozer. My guesstimate is your luck will run out, as the engine will have to be move forward to make the THM-350 fit, ie. the THM-350 will be longer than the 4 speed and its bellhousing. Be sure to add a big automatic transmission cooler.
Rob(PA)
12-14-1999 18:45:32
 Re: Re: Re: Re: V8 powered HDG6 in reply to uh, 12-12-1999 20:50:01
Try finding an old Powerglide, cast iron if possible... slightly shorter in length than the 350 or 400 tran
No Bob
12-14-1999 20:08:38
 Re: Re: Re: Re: Re: V8 powered HDG6 in reply to Rob(PA), 12-14-1999 18:45:32
There not tough enough for a dozer not even one the size of his HDG6. A powerglide is for a 2000 lb. car at a drag race that is it!
gene
01-05-2000 13:46:33
 Re: Re: Re: Re: Re: Re: V8 powered HDG6 in reply to No Bob, 12-14-1999 20:08:38
You will have all sorts of transmission problems with an automatic. If you want an automatic, go to a twin disc marine transmission and large cooler. Twin disc has transmissions that will adapt to the 350 engine and you can get a range of yokes and universel joints to fit. the only thing is the marine is just forward and reverse. If you couple it to the 4speed you will have a range of gears. There again space.
