Setting a WD throttle linkage
Dave Kolby
08-23-1998 16:54:27
My Wd throttle linkage will not set up so I can use full range of the throttle quadrent. If I set the throttle full up (idle position) and set the linkage for idle, when I go to full throttle I can only move the throttle lever about 3/4 of the way down where it stops. It will then creep back up to less than full throttle. If I set the linkage for full throttle at the full down position of the throttle arm then I can only raise it to about 3/4 up on the quadrent and it does not go to a slow idle. Both the long and short throttle rods have been adjusted per the manual. The governer is working correctly as far a speed and load control goes. Any ideas?
Dave
