HD-5 Parts
Koeckeritz Exc
12-05-1999 11:08:44
Have a few parts left to go to get shop cleaned out , also have coppys of HD -5 manual ..
nancee virostko
12-08-2002 23:16:54
 Re: HD-5 Parts in reply to Koeckeritz Exc, 12-05-1999 11:08:44
My father is having trouble getting the fanbelts replaced on his Allis Chalmer hd5 bulldozer, 1948. The neighbor helped him several yeras ago and there's a slick trick to doing it. We have been trying to push the belts off toward the back of the crank shaft where ther is a groove in which you can not see but wer are trying to push them back with a screw driver so they can slip off. Is this the correct way or the easiest without taking any other parts off if not needed to? My dad is 75 and sometimes he might forget a thing or two but they have to go on the way they came off also. Is he remembering right? He wants to replace the belts while he repairs the radiator to finish his bulldozing job down the road for x/mas money. Any help would be appreciated.
jonny
08-13-2002 06:28:15
do you have a good steering clutch?
Koeckeritz Exc
01-08-2005 16:30:56
 Re: Re: HD-5 Parts in reply to jonny, 08-13-2002 06:28:15
Have all the parts to make up one .. extra discs and have extra brake drum and clutch housing
CHARLES
01-22-2001 16:04:52
do you have a axle, left-hand side
Robert
02-05-2000 09:57:21
Wonder if you might have an "Eaton" oil pump off 2-71 engine. Or, maybe you know of a source for pump seals??? Thanks. [email protected]
mm
12-07-1999 12:46:38
Do you have any good engine mounts?
