Re: friend haveing problems with bulldozer
koeckeritz exc
12-05-1999 10:44:27
Make sure drain is open in bottom of blower box .Make sure oil bath air cleaner is clean ,and right oil is in pan /scrape all the dirt out of cup. The end seals on the bearings could be leaking or rings passing that much oil ..when running there should be air flow from drain tube if not make sure it is open ...someone screwed a plug into the one i have ....coke in MN
