Wd45 gear shift slipping out of 3rd
Lewis
12-01-1999 10:08:56
When I ride on rough ground the swifting lever comes out of 3rd gear, I checked the end of the shifter for wear,but it was not that bad. It pulls fine in 3rd, it does not slip out on any other gear. I can not hear or feel anything that might indicate clutch or transmission trouble.Any suggestions of what is causing this.
Phil
12-07-1999 17:17:16
 Re: wd45 gear shift slipping out of 3rd in reply to Lewis, 12-01-1999 10:08:56
In reply to your question. After owning many A.C.
tractors we've learn't that they all have the same problem up to the 200 series.The cause is longterm grinding of the gears.The synchromesh splines get
worn out at the end. (the tooth ends get rounded off) Since the shifting mechanism doesn't go very far into the gear compared to other tractors a little wear will make this happen.Usually in the gears that are most commonly used such as the third gear due to their gearing ratio. The correction to this problem is to either(for a quick fix) shim behind the gear that is jumping out or (good fix) replacing it completely.
mel
12-04-1999 12:39:23
My tractor has done that for years. Now 1st is starting to jump out. The local dealer said the bearings were woren. I would be grateful if you would let me know if you hear anything different.
