Ca hydraulic oil
steve
11-30-1999 18:39:08
have original owners manual..wording would seem to indicate using 20w engine oil in common sump for hydraulics..etc...have seen notes in archives..some say hydraulic oil ..some say engine oil....not sure what to use..
Phil Auten
12-02-1999 17:33:05
 Re: ca hydraulic oil in reply to steve, 11-30-1999 18:39:08
Steve,
Either one will work. They are basically the same oil. The key is that whatever you use it MUST be non foaming.
Phil
Edward Kiburis
12-01-1999 12:06:28
I've been using 20 weight, non-detergent in my C. It has the same hydraulic pump as the CA.
Tadams
12-01-1999 04:35:35
If you use 20w motor oil be sure that it is non detergent. I use a hydralic oil or a hytran type oil.
Tom
steve
12-01-1999 15:00:48
 Re: Re: ca hydraulic oil in reply to Tadams, 12-01-1999 04:35:35
thanks..have non detergent motor oil in there now but thinking of putting in hydraulic type oil..the container i have says to be used in applications where the trans,diff,and hydraulics share a common supply..didn,t know if using the hydraulic oil would possibly result in more noise from trans and drives.
