AC "C" Magneto
Jeff
08-19-1998 20:01:04
Does anyone know the correct point gap for a FMJ Mag?
The spark seems a little weak when you crank it over by hand, just wanted to make sure the gap is correct.
Also, will it hurt to run the generator without being wired to the electrical system. I would like to run the tractor before I paint and put the final touches on it. Basically I just need the generator to act as an idler to help circulate the water
Dan D.
08-20-1998 13:29:15
 Re: AC "C" Magneto in reply to Jeff, 08-19-1998 20:01:04
: Does anyone know the correct point gap for a FMJ Mag?
: The spark seems a little weak when you crank it over by hand, : just wanted to make sure the gap is correct.
: Also, will it hurt to run the generator without being wired to the electrical : system. I would like to run the tractor before I paint and put the final : touches on it. Basically I just need the generator to act as an idler to help circulate : the water
As long as the field wire is removed from the generator, everything will be ok. In other words..if all wires are removed, that's ok, too.
Mike Huber
08-20-1998 05:49:08
The point Gap is 020 I don't believe it would not hurt any thing to run the generator with out being wired God luck Mike Huber
Mike Huber
08-20-1998 05:48:33
The point Gap is 020 I don't believe in would not hurt any thing to run the generator with out being wired God luck Mike Huber
