torque spec for wd45 piston pin bolt?
orangeman-1
05-21-2008 18:41:27
I have searched my I&T manual three times and I cannot find the torque spec for the connecting rod to piston pin. I have aluminum pistons. I would appreciate it if someone could help. Thanks
Jerry Coulter
05-22-2008 07:53:20
 Re: torque spec for wd45 piston pin bolt? in reply to orangeman-1, 05-21-2008 18:41:27
AC service manual says 20 ft. lbs. Be sure to position the pin so it can't scratch the cylinder liner. There are special assembly instructions for this.
Deranged
05-22-2008 05:12:18
 Re: torque spec for wd45 piston pin bolt? in reply to ken Choquette, 05-21-2008 18:41:27
I checked my I&T as well and couldn't find it. My D14/D17 I&T manual shows the D17 piston clamp screws to 25ft lbs. So should be the same.
Jack a said: (quoted from post at 12:47:34 05/22/08) I think 25 foot pounds. Maybe someone with a book handy can help but I'm sure it is 25. Or is it 20? Better wait for somebody else.
Jack a
05-22-2008 04:47:34
