WD-45
Michael W
05-21-2008 09:20:59
Thank President Bush, I will be going to pickup a WD-45 tommorow. Dad and I went in halfs on this. I am sure I will be here asking questions from time to time since I know next to nothing about tractors.
For $1,200 we are getting a WD-45 Gas with 12volt system(upgraded) Front Hydralics, 2 buckets, Narrow front End (will go wide asap), and a Brush Hog. Current owner uses every couple weeks to mow and trim trees so it works. I have been warned it needs paint bad, and some TLC on the engin.
IOt feels like the night before Christmas knowing I will have this tommorow.
roundman
05-26-2008 10:47:38
 Re: WD-45 in reply to Michael W, 05-21-2008 09:20:59
As far as the $3.85/gal gas you can thank the oil companys and the rich people playing the stock market. I hope they get a good laugh and a real good loss
Michael W
05-26-2008 06:12:22
It is a WD-45. Still pulling information and checking but I think late 50's. The only thing that does not work is the 3 point Hydralics. Previous Owner has never used it, and thinks it was frozen when he got it.
Stinky Cheese
05-22-2008 07:03:31
You know of course that it is your (taxpayer) money that the government sent you. And also you should know, they are going to want it back not too long from now. Good luck with the tractor.
JMS/.MN
05-21-2008 12:50:03
Like old says- many components have been changed over the years. WD engine can be upgraded to WD45 power in the 201 block. Late WDs had the 45 tranny, curved lever. Bottom line is serial number. WD45 started at WD146607.
old
05-21-2008 10:21:23
Just a word of custion. A lot of WDs are sold as WD45 and they are two different models of tractors. The WD is around 34 HP and the WD45 is around 45 HP. The way to tell if the serial number and also the gear shifter and the looks of the engine. On the WD45 the gear shifter will have a curve to it and the WD is a straight shifter. The WD engine has a bolt on side plate on the right side of the engine and the WD45 engine doesn't have that plate
