Allis B Valve Cover Gasket -FYI
Carbonfibers
05-21-2008 05:35:36
I recently purchased a Victor Reinz VS38373 (Dana) valve cover gasket for my B.It measured 1/8th inch in thickness. The valve cover would not bottom out on the gasket because the valve cover hit the rocker hold down bolts.
I also purchased a second gasket from NAPA since I planned on using two cork gaskets with silicone between them. The NAPA gasket turned out to be a FEL-PRO R745664 rubber gasket 7/32nds of an inch thick. This gasket is thick enough to work perfectly and is the direct replacement for a 1945 factory rubber gasket I removed from the tractor.
I also installed a SKF 14816 lip seal on the front crank shaft and it does not leak. It replaced the original cork gasket.
Wayne
Dick L
05-21-2008 07:07:52
 Re: Allis B Valve Cover Gasket -FYI in reply to Carbonfibers, 05-21-2008 05:35:36
Good Deal, Just proves if you stay with it there is a way.
