Oil Type
William McKee
05-18-2008 18:50:28
I'm changing the oil in the PTO/Trans on my AC Model B. What type of oil do I put back in there and how much will it take?
Jeff Z.
05-18-2008 23:03:32
 Re: Oil Type in reply to William McKee, 05-18-2008 18:50:28
Just a reminder. Did you drain all three places?
There are two reservoirs that have to be drained.
Jeff Z.
05-18-2008 20:46:37
Been using 20w non detergent motor oil in our two B's and two C's transmissions for 40 years and never had a failure. It works fine.
steve(ill)
05-18-2008 19:08:12
it takes 8 quarts. originally they speced 20 wt oil. Today the new oil is universal hydraulic- transmission fluid. You can also use JD or Case oil such as Hytrans or HyGuard. Regular 20 wt oil will work, but motor oils can foam and have addatives that are not required in a hydrualic system.
