I may have saved $110
Jack a
05-13-2008 04:41:57
$110 for range cable a month ago when I checked. I cut mine apart at one end and pulled it apart and lubed it up with a real light oil (maybe should have used graphite instead) and then brazed it back together using a copper sleeve I made to reconnect the cable. I made a steel sleeve for the short outer tube and soldered that together. Works great now and saved $110. To get at the cable on top of tranny just remove the floor plate and it's real easy. I tried this fix because I figured at worst I would be out a little time and at best I would save $110.
Just a thought as I have seen plenty post here with range cable troubles. The one that was bad was the heavier of the two but I assume the same fix could be used on the lighter second cable too.
Jeff Z.
05-13-2008 07:08:03
 Re: I may have saved $110 in reply to Jack a, 05-13-2008 04:41:57
It is always good to get the problem fixed without spending money.
I broke the hood release handle on my Jeep. I think the new cable wa $65.00.
I put some pliers in the glove box and when I need to open the hood I just pull the cable with the pliers. Problem solved. No Charge.
