pelle
05-14-2008 08:24:59
Re: Allis B, strange engine rpm... in reply to pelle, 05-12-2008 11:31:44
Ok, so Im back! With no luck... sad to say. Well this is the story for now; I have checked and cleaned the carb so no that one is ok. And in fact, she starts, just like before and runs almost, but just almost ok on low rpm/idle. When i give her some gas she starts to spitt/blurr again, just like before and everytime she spitts, small amount of white puff-smoke comes out of the pipe. She sounds just like if she is "looking" for the best running rpm, but cant seem to find it. (I have also tried to "turn" the whole magneto when she runs, to se if that did help... but no.) If You understand. Again I have to ask, do You think I have made something wrong with the magneto anyway, when I putted it together after installing the coil?. How "bad" is it if I, lets say, "miss" i teeth or two on the gearwheel? the have to match the "A" or "C", but what happends if I miss one or two, lets say one teeth to the right, or to the left. Its hard to see if the match exact. Or could it still be someting else? I mean, in the first place, after the first attempt to start after changing the coil and condenser, she did run ok, for lets say... 5-7 min. and then she started to behave like this... Please Guys, any idea? (more than You so kindley allready have given me!) Best Regards Per
